Hi Ross,
Try this
KFLOP JP6 pins--------KFLOP Names------Keling Old Name----Keling New Name---Keling Item Number
Pin8 GND COM MPG 0V
2
Pin1 5V 5V +5V 1
Pin3
3.3V COM select COM Control Switch 14
Pin5 IO26 A A
3
Pin6 IO27 B B 4
Pin7 IO28 X
select X axis 7
Pin10 IO29 Y select Y axis
8
Pin11 IO30 Z select Z axis 9
Pin12 IO31 X1 select
X1 11
Pin13 IO32 X100 select X100 13
Regarding your questions:
#1 - not sure what you mean. There are a few unused pins. Just make the 10 connections shown above.
#2 - to save a wire and an I/O bit, the software program assumes X10 if neither X1 or X100 is selected
#3 - usually the stop switch is connected to the main estop relay for the system and not directly to KFlop
#4 - I think "COM Control Switch" means that it is the common node fro all the control switches. We connect this to 3.3V so that when the various control switches close the corresponding IO gets pulled up to 3.3V. Those IOs have internal pull down resistors so when the control switches open the IO drop low.
#5 - yes 0V is GND for their manual quadrature encoder.
Hope this helps
Message: 334 |
Date: 4/28/2010 |
Subject: Re: Connecting Keling MPG2 pendant |
Thanks Tom,
Your help is always very much appreciated and that clears up that hazy bit.
How does Mach3 call the Init3AnalogPlusMPG.c program?
Or is it to be copied into the init.c file?
Ross
> Hi Ross,
> Try this
Message: 336 |
Date: 4/29/2010 |
Hi Ross,
Yes the parts of Init3AnalogPlusMPG that relate to the MPG need to be merged into your init.c file. Basically the loop at the end that services the MPG and a few definitions.
Message: 338 |
Date: 4/29/2010 |
Thanks Tom,
That's sufficiently vague enough to have me wondering what to leave out :)
I can figure that I don't have to replicate what's there, in the existing Mach3 init.c file but "a few definitions"??
I will go through it again but it is, for me, like wading through mud and wondering if there is some quicksand lurking there to swallow me.
I realise that if I leave some code out that it won't work.
But if I leave too much in does it matter?
Ross
> Hi Ross,
> From: fermanz <ferman@...>
> Sent: Wed, April 28, 2010 8:27:55 PM
> Subject: [DynoMotion] Re: Connecting Keling MPG2 pendant
> Thanks Tom,
> How does Mach3 call the Init3AnalogPlusMPG. c program?
> Ross
> --- In DynoMotion@yahoogro ups.com, Tom Kerekes <tk@> wrote:
> > Hi Ross,
> > Try this
> > KFLOP JP6 pins-------- KFLOP Names------Keling Old Name----Keling New Name---Keling Item Number
Message: 339 |
Date: 4/29/2010 |
Hi Ross,
Sorry for being vague. If you leave out a definition the compiler will usually complain. So one approach is to move things in until the compiler stops complaining :}
The definitions are:
#define QA 26 // define to which IO bits the AB signals are connected
#define QB 27
int BitA,Change1=0,Change2=0, DiffX2;
int PosNoWrap, NewPos, Pos=0, wraps;
double Factor=0;
